maint. req. light
Old Jun 19, 2004 | 03:27 PM
pooker's Avatar
pooker
Default maint. req. light
how to reelase maint. req. light in Lexus ES 330?
Old Jun 19, 2004 | 07:58 PM
Toysrme's Avatar
Toysrme
Cool
I have no idea. If you want something easy to try, reset the ECU. Normaly you do this by pulling the EFI fuse for 10 seconds with the car off. If that doesn't get it, pull the negative battery terminal from the battery & then pull the fuse.
If the car runs funny for a little while no worries, it has to readjust.
Old Jun 19, 2004 | 09:44 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
Default Re: maint. req. light
This has been discussed before in the other Lexus model forums.
Many 2004 Toyota and Lexus models have a new reminder light which is the MAINT REQ'D light which is ONLY an oil change reminder light. This light goes on at 5k intervals and can be easily reset on your own. THIS IS NOT CONNECTED TO THE ECU nor will it affect performance.
All this info on how to reset the light is located in your owners manual. I would suggest you consult that because it is a wealth of information. I myself have an 04 IS300 that has this same light.
Not sure with the 04 ES but with the IS and most other models, you must hold the tripmeter button down before startup...and hold it down as you turn the key from the OFF position to the ON position. The odometer will flash to zero and the light will blink then turn off. As soon as the odometer flashes zero, it means the maint req'd light was sucessfully reset.
Good Luck.
Old Jun 19, 2004 | 09:45 PM
flipside909
Lexus Connoisseur
25 Year Member
Old Jun 19, 2004 | 10:17 PM
Toysrme's Avatar
Toysrme
I was going to say good find, but you don't have to be a jerk...
Old Jun 20, 2004 | 09:47 AM
flipside909
Lexus Connoisseur
25 Year Member
Look at it this way. If you don't know what you're talking about, don't suggest unless you really know.
Old Jun 21, 2004 | 04:42 PM
JenzLEX's Avatar
JenzLEX
On my '97 accord, there is a small hole beside the light and you just stick your key in there to reset it. Pretty neat.
chuckyarla
Oct 26, 2012 05:57 PM
AllenISF
IS F (2008-2014)
15
Dec 22, 2008 09:48 AM
jnguyen
Nov 4, 2004 02:09 PM
