KYB upper mount
Old Nov 16, 2025 | 03:52 PM
elfpcf's Avatar
elfpcf
Default KYB upper mount
OK, low on cash. Have had 2 sets of Monroe quick struts installed on 2007 ES 350. Both sets have a clunk in the upper area of the strut over a small bump. I am told that the Monroe struts have problems with the upper mounts. Will a KYB upper mount fit the Monroe and stop the clunking.? fingers crossed Ed
Old Nov 18, 2025 | 10:15 AM
Clutchless's Avatar
Clutchless
A KYB or OEM mount that is listed for your vehicle should fit over the Monroe struts.
Have you tested the tightness of the strut bolts?
You do need a spring compressor and the know how to safely take apart the strut. Or you could remove the strut yourself and pay a local shop to compress the spring and swap the mounts.
I did this once on a Mazda when my spring compressor did not fit the struts.
They could also provide their professional diagnosis of the noise source at the same time.
Old Nov 18, 2025 | 12:22 PM
ESh's Avatar
ESh
You don't need to replace the mount unless the mount is torn/rusted.. Replace the bearing only.
Part number: 90903-63014
Old Nov 19, 2025 | 06:49 PM
elfpcf's Avatar
elfpcf
Clutchless, everything is tight as it should be. I don't have a spring compressor, I must go to a machine shop. It may be more expensive to rig up the Monroe than just go buy KYBs. Then the labor will be over $1300.
ESH, these are new Monroe struts. Would the bearings be bad on two sets of fronts?
I may have to live with this noise for a while. It is getting to be too much.
God bless you 4 your help. Ed
Old Nov 20, 2025 | 11:28 AM
SunglassesGuy's Avatar
SunglassesGuy
if you just bought these you should be able to do a warranty. if it was rock auto, they used to have a pretty good program. been a while since I've used one tho
Old Nov 20, 2025 | 03:36 PM
elfpcf's Avatar
elfpcf
Sunglasses, yes I bought them locally and there is a warranty but not for labor. So far parts have been $305.00 and labor $630. Unless I find cheep labor there will be another $175.00 ish ! If I go for a second warranty claim I will buy KYB this time.
Thanks Ed
DMPesso
Apr 16, 2023 05:51 PM
dpalinsk
Jul 2, 2021 03:42 PM
NyCrAzY
RX - 1st Gen (1999-2003)
Oct 26, 2011 12:44 AM
Mike ES
Maintenance
Jan 3, 2009 04:36 PM
TRoyals14
Dec 20, 2005 10:00 AM
