Help! 96’ es300 code P0500
Old May 3, 2025 | 06:15 AM
Tushawn35's Avatar
Tushawn35
1st Gear
Default Help! 96’ es300 code P0500
I bought a 96’ es300 for my wife last summer and started to do a mechanical refresh. I changed the timing belt, water pump, plugs,wires, filters, calipers, rotors, cv axles, and suspension. Just when I thought I had it completely sorted I got a P0500 code. I replaced the VSS, but the code came back. The speedometer and cruise control work fine. The transmission does some funky things though, the fluid is good and it shifts fine manually. Does anyone know the procedure to test whether it’s the cluster or ecu? Any help would be greatly appreciated, I have a Haynes manual, but it’s basically useless. The research I have done always brings me back to either a bad cluster or ecu.
Old May 3, 2025 | 08:55 AM
See this thread
https://www.clublexus.com/forums/es-...00-solved.html
Not sure if the above also applies to a 1996.
Old May 4, 2025 | 07:20 AM
TaninAuto's Avatar
TaninAuto
Sponsor
Cluster
https://taninautoelectronix.com/prod...ument-cluster/
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
https://taninjdm.com/
Our Lexus LS430 Dealership
BatNgan
Dec 4, 2022 05:42 PM
Takomac
Sep 26, 2022 02:45 PM
wan8dan
Feb 23, 2017 11:01 AM
mhusted318
Apr 1, 2015 04:13 PM
sc300Super
Feb 28, 2012 06:06 AM
