One teed off customer.
Old Aug 4, 2024 | 12:20 PM
afpj's Avatar
afpj
If you did not gas up to reset the fuel mileage after the service, the very slightly lower gas mileage may be due to the test drive they take after such a complete service. Computer memory may have also been reset and as someone mentioned already, the transmission has to learn your driving habits again. Aside from that, I'm curious why they changed the spark plugs so early, typically don't need change spark plugs on these engines until past 100,000 mi. The other question is then, what spark plugs did they use to replace the originals? The wrong spark plugs can affect fuel mileage.
Old Aug 5, 2024 | 01:45 PM
rmak's Avatar
rmak
I see no issue with the items you had serviced. As stated, it will take a while for the electronics to adjust. I recommend driving it normally and it will adjust over time, or you could take it back to the dealership and ask them to "re-learn" (reset using techstream) the engine and trans ecu.
Fill it up with 93 octane and drive it like you stole it.
Old Aug 10, 2024 | 12:43 PM
703's Avatar
703
None of what you performed improves mpg if there were nothing wrong with these things to begin with.
now you know.
Old Aug 11, 2024 | 09:19 AM
Audiobahn20's Avatar
Audiobahn20
I think you may have a misunderstanding of what can play a toll on fuel economy, as almost everything he mentioned has an effect on fuel economy no matter how small or large.
Anything that has a weighing factor on engine efficiency will lead to fuel economy influence, and as soon as you place a maintenance item into service it begins a life cycle or decline in efficiency. Efficiency is a loaded word in this instance because it includes so many factors, but all things are relative...
richy350
Dec 6, 2019 01:41 PM
pam1980
Hybrid Technology
12
Oct 27, 2018 08:35 PM
Moogy
May 4, 2011 12:28 PM
2IS350DT
Maintenance
Feb 21, 2011 11:31 AM
