Replace in pair or not
Old Apr 18, 2024 | 08:32 AM
DatBoi's Avatar
DatBoi
9th Gear
Default Replace in pair or not
Just found out that my front driver side cv boot was torn, might been driving like that for awhile now. Looking to replace the axel myself. Should I be replacing both axel or only one since the other one seems to be normal. I'm also replacing the inner tie rod on the front passenger side since it have side to side play and I can see the tie rod moving in and out, the driver side is fine. Should I also be replacing them on both sides?
The car is a **** box as in everything is worn, paint, seat, plastic, wood, etc. so not looking to pour a bunch of money in. Will maybe keep the car for like 3 more years and then junk it.
Old Apr 18, 2024 | 09:32 AM
CELSI0R's Avatar
CELSI0R
Only replace the one that's failed. No sense in replacing the other if it's fine
Old Apr 19, 2024 | 03:55 PM
bc1_2002's Avatar
bc1_2002
CV axles are independent of other axles, including tie rods and ball joints. Not so for such items as struts and brakes, although brakes are independent, one would want the pads to wear evenly. The key word is independent.
Good to ask.
Old Apr 19, 2024 | 05:48 PM
rigged87's Avatar
rigged87
I did one at time about 20K miles apart. No issues.
Culi
RX - 3rd Gen (2010-2015)
12
Apr 5, 2024 08:04 AM
Asher
Nov 21, 2012 11:35 AM
Luke27617
Mar 26, 2012 08:34 PM
kpazzo6
Suspension and Brakes
Jun 15, 2011 12:23 PM
paintrain
May 17, 2008 07:55 AM
