Code reader software for 2008 ES350
Old Apr 29, 2023 | 06:50 PM
adjit's Avatar
adjit
3rd Gear
Default Code reader software for 2008 ES350
Hi, I have an OBD2 cable to connect to my PC. Does anyone have some software recommendations to read the fault codes from my car? Definitely getting some misfires and a check engine light
Thanks
Old Apr 29, 2023 | 07:58 PM
adjit's Avatar
adjit
3rd Gear
Default PC Code Reader Software
My 2008 ES350 has the check engine light, and vcs on. Engine definitely seems like it's misfiring. I have the spark plugs, and was reading it could be the coil packs. Would like to get a read on the actual faults. I have an OBD2 cable for a PC, does anyone have a software recommendation so that I can see what the fault is?
Thanks
Old Apr 29, 2023 | 08:22 PM
bucfan22's Avatar
bucfan22
The car is 15 years old. If you gonna spend your time or paying someone doing the spark plug may as well replace all the coils and be done with it. 3 spark plugs on the back is a bit more difficult to tackle.
As for software i believe Techstream is what it called. You can buy cable on amazon or ebay for $20-$40 specifically made for working with techstream and toyota or lexus.
Old Apr 29, 2023 | 08:43 PM
Techstream.
Old May 1, 2023 | 11:04 AM
spaceballs's Avatar
spaceballs
If you're strapped for cash, I would replace all the coil packs at the back first, then move all the old good ones to the front, that way, you know your rear coils are going to be good for a long time, and the front ones you can replace quite easily.
danielnas
Aug 1, 2020 12:23 PM
75damien
Mar 3, 2020 11:29 AM
danielnas
Maintenance
Nov 6, 2019 08:31 AM
KGB1964
Sep 22, 2019 02:39 AM
Frieseb
Mar 27, 2014 07:31 AM
