No power to start button
Old Apr 24, 2023 | 01:07 PM
  #31
larrykessl's Avatar
larrykessl
For the life of me I cannot remove the fusible link that is next to the fusible link that’s bolted in. I’ve removed the nut holding it to the bolt connecting the alternator, but it won’t budge. I release the little tab on the right side as well, still it won’t budge! It looks like it would just slot in, but something is holding it in, unless it is rusted in place? No evidence of that though. Should I just brut force yank it out, or is there something else holding it in?
Old Apr 24, 2023 | 01:31 PM
  #32
ESh's Avatar
ESh
I think it has more than one bolt.
Old Apr 24, 2023 | 02:48 PM
  #33
larrykessl's Avatar
larrykessl
Yes, I got the two bolts for the other fuse link and took it out no problem. It’s the other fuse link that I can’t get out
Old Apr 25, 2023 | 12:08 AM
  #34
ESh's Avatar
ESh
This one?
Old Apr 26, 2023 | 05:18 AM
  #35
larrykessl's Avatar
larrykessl
Yes, that is the one I can’t get out
Old Apr 26, 2023 | 06:03 PM
  #36
TCoolest2's Avatar
TCoolest2
Can you take a video to show us? If there's rust, can also be causing high resistance
Old Apr 27, 2023 | 03:26 AM
  #37
ESh's Avatar
ESh
DId you remove that one bolt that holds it?
Old Apr 27, 2023 | 02:12 PM
  #38
larrykessl's Avatar
larrykessl
Yes, of course. I also released the tab on the side as well, but it still WONT BUDGE. Super frustrating... I'm not sure this has anything to do with my starting/power issues though; maybe just coincidence.
Old Apr 27, 2023 | 03:22 PM
  #39
ESh's Avatar
ESh
I bet it is corroded or melted.
Check this video:
Old Apr 28, 2023 | 04:30 PM
  #40
larrykessl's Avatar
larrykessl
Main problem solved! There was a loose wire from the fuse box in the engine area: had to remove the bottom piece of the fuse box to get to it. Thanks everyone for your input and encouragement. I had called AAA to have it towed to the Lexus dealer this morning, but when they showed up they wouldn’t tow it because the tags aren’t current( ridiculous). Figured I’d give it one more shot and it worked out
Old Apr 29, 2023 | 12:52 PM
  #41
TCoolest2's Avatar
TCoolest2
Wow! Great news. Glad to help
Old Dec 31, 2023 | 08:27 PM
  #42
travis0917's Avatar
travis0917
1st Gear
Default Which main fuse, box, and which wire?
i’m having the same issues. Car went in for new brakes and ever since key fob does not recognize vehicle and no power at push button or on dash.
Shaboom
ES - 7th Gen (2019-2025)
39
Sep 13, 2021 03:50 PM
chemist
RX - 3rd Gen (2010-2015)
22
Apr 19, 2021 05:50 AM
willyinnv
18
Jun 6, 2020 10:22 PM
anomale
Oct 20, 2015 11:44 PM
scutmud
19
Feb 24, 2014 01:10 PM
