Where is the return coolant hose to the radiator? 1995 es300
I've read in a couple places that it might be best to drain coolant from this hose instead of trying to open the radiator drain plug (especially if it hasn't been opened in a long time....like mine sadly). I want to change my thermostat and drain prior to doing so, Can someone please help with a pic maybe?
Left hand side of the car, area below the battery. it is probably easier to crack open the drain plug the rad hose fuses to the radiator and will require some effort to break the bond.
Ok, that makes sense. Is the radiator drain plug in a similar location as the '97-'01? It's getting hard to find specific images/videos for a 1995.
About the same place towards the right hand side of rad as you face the engine. For some reason Denso likes to make it so the wings on the plug face the worst possible position, hard to get a twisting motion with your fingers.
How many miles on your car? Rads on these cars tend to last about 200K miles before the tank cracks and fails.
Consider replacing the radiator.
With shipping likely won't be worth buying from an online Toyota dealer. That could change if you decided to throw in upper and lower rad hoses. The Denso on Amazon is $20 cheaper than on Rockauto that's unusual.
By sheer chance, I recently replaced the radiator on my 1992 ES300.
I was lucky enough to find a genuine OEM radiator for sale by a mechanic who was happy to sell it for next to nothing.
So here's what I can tell you about changing the radiator on a 1992-1996 ES300.
If you're not careful it can be messy... because you'll be disconnecting not one, not two, but THREE fluid sources.
Firstly, you'll be disconnecting the obvious engine coolant hoses.
Secondly, you'll be disconnecting the high pressure power steering pumping connection to the hydraulic motor on the radiator fan, and you'll also be disconnecting the low pressure "return" hose from the fan too.
Thirdly, you'll be disconnecting the high and low pressure Automatic Transmission cooler connections at the bottom of the radiator.
As you might imagine, the hydraulic hose connections and the Automatic Transmission coolant connections will potentially be VERY messy.
I strongly recommend lots and lots of sheets of cardboard to catch the inevitable spillage under the fan area.
But like most things automotive, the sense of satisfaction for a job well done is worth it at the end.
I didn't disconnect the hydraulic fan motor/lines worked around it. Shorty after that the line going around the back of the block and to the fan motor started leaking, that is a difficult part to replace.
As part of my car's "major maintenance" in 2019, we dropped the entire engine while still mounted to the subframe out from under the car and we replaced a whole bunch of stuff while we had loads of access. Including all the hydraulic lines you mentioned.
All of which confirms a fundamental truth about the 3VZ-FE and the 1MZ-FE engines... the power steering pump is in a dreadful position isn't it?
