Vacuum Smoke
Vacuum Smoke
Looking for some help on where to connect a smoke machine on a 2002 ES300 to diagnose a small vacuum leak. This has been an ongoing problem for years. Attempting to tackle it once again.
Hello,
Depends on what you are trying to check. If it is the vacuum system under the hood, use a tee adapter to tap into any of the vacuum hoses, if it is EVAP system, there is a service port on the Driver's side that you can use.
Hope this helps and best of luck!
Thanks I appreciate your help! I assume you're referring to the green service port on the drivers side. I hope to tackle it this upcoming weekend.
iAmbusher
11-28-21 03:04 PM
Piraiba
12-03-13 04:07 PM
mpringle
06-05-09 06:52 PM
