Fob
I have the same issue on my 1998 with new batteries. What I noticed is the battery holder in the fob is very loose or damaged from previously installed batteries that were oversized for the compartment. I decided to splurge and order one brand new fob from the dealer to see if it will increase the range. I will update you with how well it works in about a week.
The antenna for the wireless door lock system is placed inside the Door Lock ECU, which is located under the ash tray, right beneath the climate control unit. It is pretty easy to access and take apart, as far as I recall, so you might as well try taking a look at it. They can also be found for less than $10 on eBay, as one of the last resorts..
Hope this helps and best of luck!
