P0137 cel code b1s2 downstream
Old Dec 21, 2021 | 05:23 PM
swapnil's Avatar
swapnil
Exclamation P0137 cel code b1s2 downstream
I own a 2005 Lexus ES330. The check engine light comes on often and goes away. My mechanic diagnosed with OBD2 scanner and found out low voltage problem on bank 1 sensor 2 oxygen sensor (P0137 CEL CODE B1S2 DOWNSTREAM).
How much will it roughly cost to fix the issue?
Old Dec 21, 2021 | 05:43 PM
Did your mechanic give you an estimate? Should be 1 hour plus parts, maybe 1.5.
Old Dec 21, 2021 | 05:47 PM
swapnil's Avatar
swapnil
Ya around 400. Seemed too much.
Old Dec 21, 2021 | 05:51 PM
Arsenii's Avatar
Arsenii
Hello,
Sounds like an overkill.. It is something that you can do yourself for less that $100 if you have a set of hand tools, jack and a jack stand, given that it is not seized in there for good. Here is a thread about B1S2 location and replacement on those cars.
Hope this helps and best of luck!
Did the mechanic cost out labour and parts or just gave you a total. These are generally very easy to replace.
Fritz330
Jul 3, 2016 07:45 PM
oneblackgt
May 6, 2011 11:11 AM
nicos1
Oct 8, 2007 12:44 PM
squeekyM
Sep 26, 2006 07:36 AM
