300k transmission service (98)
1998 ES300
300,xxx miles
I was afraid fluid was leaking between the engine and the transaxle, but after a cleaning it looked more like the old pan gasket started to seep and spray fluid everywhere around it.
This is my second oil pan gasket and strainer replacement. First one was around 180k in 2012. Ever since then I’ve kept up with periodic fluid changes with synthetic ATF about every two years or 30,000 miles.
New gasket, new strainer, new bolts, new drain plug, 6 quarts of Mobil 1 Synthetic ATF, and a few coats of paint.
The before
Back of the pan
Drips on the exhaust hanger.
After degreasing
Gasket is already weeping
Very pleased with how clean everything was.
Pan looked a little dirty but nothing unusual.
Magnets were filthy but pretty normal for what I’ve seen.
Strainer removed
Old strainer
New strainer
New strainer installed
Most of the bolt holes started to rust
Wire brushed
3 coats of chassis black
New drain plug as an added bonus
Finished product
All back together
Total fluid removed was just over 3.5qts; drain plug only: 2.75qt; w/ pan removal: 3.25qt; w/ strainer removal 3.5qt
New fluid in!
300,xxx miles
The before
Back of the pan
After degreasing
Strainer removed
Old strainer
New strainer
Wire brushed
Finished product
All back together
New fluid in!
You need to half your OCI that's a fair bit of clutch material ending up in the pan. Good on you for doing the maintenance yourself.
djr48312 (06-18-21)
I'd be questioning about the possibility of the paint inside the pan flaking off. On my Sentra, I didn't paint the inside of the pan because I thought there was a possibility of it flaking off due to poor prep, adhesion and how ATF and heat would affect the paint. I left it bare which I know isn't a great idea, but it's been 200K miles since and no problems.
Why didn't you also drain the differential while you were at it?
I just did this pan-drop operation recently @ 293K miles, having only done a drain & fill (trans & diff drains) once since I bought the car @ about 245K. I was shocked at the quantity of grime and ferrous sludge I found clinging around my magnets. I'm also hopeful it was due to the time, shortly after I took ownership, that I heard whining from the transmission/transaxle and found that the ATF level was too low, topped it off, then did a transmission/differential drain & fill.
djr48312 (06-18-21)
At first I thought the inside of the pan was painted but it's an optical illusion. A540E has separate chambers for the trans/diff A541E does not.
I tried it once before and almost broke the plug. If I recall correctly, there is very little room between the plug and the subframe, so I couldn’t fit a socket and ratchet in there and had to use a regular Allen key and a hammer. I think I finally got it out but barely any fluid came out of the differential hole so I decided to never mess with that plug again. The transaxle shares fluid with the differential so there is no point opening the second drain plug.
Wait I need to investigate this differential fluid further. My understanding is they share the fluid because it’s refilled through the dip stick. Is there a separate fill plug for the differential?
I’ll double check next time I’m under the car, maybe I had it all wrong in my head.
Hayk (05-29-21)
Hayk (05-29-21)
Good thread and pics! I’ve never done this myself on my ‘99 with 225k miles, so very interested to see what it looks like up there. I agree with you: very clean looking. You have inspired me!
I love it!!! Great post and work.
I've not been checking in here as much as I should. I love what @hayk did as I'm a fan of fixing any little worn/rusted/hardware when I am working on my own cars. Here's some pics of my (new-to-me) DD Volvo ur-XC. I had a similar condition P2 XC70 until January when a semi driver decided to demolish it (and my back). Anyway, I refinish stuff as I work on it. On parts I modify/tweak that are out of sight, I re-do in what they call "Swedish Racing Green" ( a joke on BRG - swedish racing colors are a bright "Ford Blue" going back to the 1920s).
Anyway, I love it when people take the extra few minutes to strip/prep/prime/paint parts to re-install. If you get in the mind-set, it really takes no extra time as you do it as a little break between other steps in the main repair work.
Love it, Hayk!!!
My 2000 Volvo turbo I have been similarly refurbing:
The grand-daddy, 1983 BTCC racer:
Love it, Hayk!!!
Hayk (06-28-21)
smirnoffsk
Lexus Vehicles Classifieds
03-04-17 06:39 PM
