Gasket between 3rd cat and resonator
Hey,
life in the salt belt can be rough. But, recently I was blessed with a zero rust completel exhaust from flange after the their cat to the muffler, all original for $30.
Does anyone know the part number for the gasket for the flange between third cat and resonator?
thanks
thanks
90080-43033
Walker gaskets are very similar to OEM and cheaper, do not use a solid aluminum gasket it will melt and gall into the metal and cause damage.
That’s man!
the flanges were relatively perfect considering the source . Used a walker but it leaves a decent gap. Probly 3/32. With our salty environment that’s not good. Also it can bend the ears of the flanges. I’ve got 3/8 size standard flat washers in there now. I wonder if there is a liquid gasket or something I could use?
I've never had luck with exhaust gaskets in a tube type products they don't last. I know what you mean about the gap use muffler wrap to seal it up the stuff will degrade after a few years then wrap again.
