High mileage, Knock sensor replacement
I have a 2000 ES300, I'm getting a code for #2 knock sensor and I can tell right away how bad the performance is and driving with that high RPM is not fun. Car has almost 300KM, I sometimes put 1000+KM a week so lots of city driving. I did the timing belt at 250K, car runs smooth and decided I want to keep it and do the work, so what is a good idea or "might as well" change since I will be taking out those covers? like hoses, seals, sensors,etc?
This is my list so far: Knock Sensors, Wiring Harness, Plenum Gasket, Right+left intake gaskets, Bypass hose. I will also change spark plugs, pcv valve, air filter, fuel filter. All parts will be OEM.
Any tips or recommendation is much appreciated
Are the cam seals leaking?
Barnabas
11-13-17 12:31 PM
shickalee
16
01-18-15 01:43 PM
jbriley3
04-12-12 12:48 PM
