2003 Lexus ES300 noise when accelerating
Holle folks, my es300 makes weird noise when accelerating from stop still or (1st and 2nd gears).
it sounds exactly like this YouTube video
https://youtu.be/3O9_zMqQ6-M
But it sounds like marbles in a can.
Dont want to say it but it maybe detonation/spark knock.
Especially if its happening in the lower gears under load.
Quick step to rule it out (hoping) is run the gas close to empty and fill with premium gas.
Newes300 (01-19-19)
+1 on HomerJay's response! I had the same noise, replaced the passenger side upper motor mount (aka torque strut mount), and the noise was gone. As I pulled the mount pieces fell out.
Newes300 (01-19-19)
Hey mine is making this exact noise right now and I can see that the torque mount is broken. Its been this way for the past few years and my guess is that its finally giving out to the fullest. I actually have the part already so it might be time to install it
Save yourself the price of a full tank of expensive gas. Look at the rubber in the dog bone and see if it's deteriorated. It's very easy to replace if it's the culprit. 15" max. On my 2003 ES it was p/n 12363-20120. Go with OEM. It'll be worth it in the long run. Take a close look at all your other mounts, too.
Can't imagine that a low temperature of the coolant would create any noise at all (possibly pre-ignition), but if you're seeing a low temp and the thermostat has never been changed, then, by all means, go ahead and change it. Please use an OEM thermostat. You'll be glad you did. If you're getting a code P0128 and the coolant is low teimp that might, (and I don't know for sure), present a preignition knock. Just be prepared for a lot of parts to yank out and reinstall. While you're in there you might as well replace the well hidden hose, water by=pass, NO.1 (1626120010 on my 2003 es300). It's subject to high temperature and, heck, you're already there (mostly) so why not? You've got a lot of parts to take out on your way to the thermostat so make sure that you get everything back as it was.
Let us know how it goes and good luck.
HOSE, WATER BY-PASS, NO.1
Genuine Toyota (1626120010)
So the thermostat is on the drivers side of the engine, correct? At that point ill have the airbox and a lot of hoses removed. How much further do I need to go to get to the water bypass hose? I cant find a whole lot of info for the v6 es300's
Bypass hose is under the plenum and intake a fairly extensive job. There are plenty of vids on YT any car with the 1MZ engine (which is many) is the general procedure you follow.
Yes, the thermostat is on the driver's side of the engine.
This is a good video on just the thermostat replacement. It's on a 330 but everything is just about the same as on the 300: https://www.google.com/search?newwin...id:eA6YAOX1WOM
The replacement of the bypass hose is pretty involved. Here's a video for 2003 ES300: https://www.google.com/search?client...id:X0swOyx4z6c
I checked the part number at different Lexus sites and it's a good number as LeX2K indicated. I agree with getting the part from a dealer to be sure it's OEM.
AntzCro
03-16-15 06:46 PM
Ravencrave
09-09-14 06:32 AM
