91 Es250 Ecm
Old Jun 13, 2018 | 06:50 PM
Lex91's Avatar
Lex91
Default 91 Es250 Ecm
Hello, its been quite a while since I have been here, but I need to see if anyone knows where the ecm is located on my 91 ES? I have tried to find the info on Google and here with no luck.
thank you
Old Jun 13, 2018 | 07:04 PM
Inside the car direct center by the firewall. Pull the carpet back on both sides you'll see it, held in by two 10mm bolts.
Old Jun 13, 2018 | 07:11 PM
CELSI0R's Avatar
CELSI0R
Hi Lex91,
I would assume that it is in the same location as the 1988 - 1991 Camry, which is under the dash in the middle section.
Here are some instructions from a Toyota forum on how to get to it:
http://www.toyotanation.com/forum/10...l#post10768937
Here is a diagram:
Here is another diagram:
Hope this helps.
EDIT: Confirmed by Lexus2000's post.
Old Jun 13, 2018 | 07:15 PM
Lex91's Avatar
Lex91
I found it thank you!
Old Jun 13, 2018 | 07:26 PM
Why do you want to remove it?
Old Jun 13, 2018 | 07:31 PM
Lex91's Avatar
Lex91
Well, because of the weird things the car is doing that would have pointed to a tune up or o2 sensor but everything has been replaced which leads me to believe that the computer might be going out.
Old Jun 13, 2018 | 07:37 PM
I've never seen one go bad but it is possible. Oddly enough the ES250 ECU is not the same part number as used in the Camry.
Old Jun 13, 2018 | 07:50 PM
Lex91's Avatar
Lex91
From what I read its possible but Im not sure what else it could be so I have to start there i guess. I did find one on eBay for 34.00 tho
robdog
Jul 8, 2024 02:20 AM
Qek585
Jun 26, 2018 02:00 PM
LanceLink
Jan 15, 2018 01:34 PM
Nemesis400
Mar 16, 2010 12:29 PM
2000ES300
Jul 20, 2006 10:49 AM
