1999 Lexus ES 300 throwing Codes :(
Going to attempt to summarize initially, we can get detailed later if need be:
Purchased vehicle used 1/8/18, 199,300 Miles. Right away changed Air Filter, Engine Oil, Radiator Fluid.
Issues began 1/29/18
- Acceleration hesitation ( & Putting )
- Check Engine Light - Trac Off Light ON (No Blinking)
- RPM Fluctuations, Shifting seemed off timed/balanced.
Actions Taken:
- Cleaned Mass Air Flow Sensor & IVAC
After that reset codes, no problems all fixed until later on.
2/19/18
Driving symptoms:
- High/Low Idle
- Misfires/Rough Ride
- Engine Light & Trac Off ON (Blinking Engine when misfiring)
Ran codes first time:
- P1354 VVT System Bank 2
- P0300 Random Misfire
- P0302 Cylinder 2 misfire
- P0304 Cylinder 4 misfire
- P0306 Cylinder 6 misfire
Recommended Parts to change by Autozone: VVT Actuator
Actions Taken: Checked & Cleaned Oil Control Valve / VVT Actuator. Autozone said that was the part that was throwing codes
& needed to be replaced.
2/23/18
Same Issues as 2/19 without blinking Engine Light
New codes 2nd time from Autozone 200,700 Miles:
- P0302 Cylinder 2 Misfire
- P0306 Cylinder 6 Misfire
- P1153 A/F Sensor Circuit Response Malfuction Bank 2 Sensor 1
- P1351 VVT / CMP Sensor Range / Performance
Recommended parts to change: Replace Ignition Coils & Spark Plugs
Visual observation on motor Coils 2 & 4 have been replaced I don't know when no service record kept by previous owners.
Any info on what the issue might be would be greatly appreciated Thank youuuu
Actions Taken:
2/19/18
Driving symptoms:
- High/Low Idle
2/23/18
The first set of codes are classic symptoms of a bad OCV. I'd just replace it before I did anything else. They're not that expensive, about $45 for a Dorman. At 199K it's probably worn out. Note all the misfires are on the same bank. I assume you cleaned the Bank 2 OCV screen.
FYI the flashing CEL indicates a serious problem, in your case misfires.
Gotcha thanks! BTW, I cant seem to find any online references to where the screen is actually located maybe help me out & tell me where that little bugger is located? Thanks again bud!
Jordan95
01-22-18 07:23 PM
zfox
03-08-13 05:21 AM
