help with servo part #063700-7801
2003 Lexus ES300 North America: I am trying to find the current part # for the servo at the right knee of the driver. I believe it is a mixing servo. The part that I removed from the car has the part # 063700-7801 stamped on it. When I search Toyota/Lexus parts sources, it does not come up when I type the number into the search. There are a few used ones on Ebay, but I would like to explore the possibility of purchasing a new one. This servo has the plastic arm glued to the spindle. It is impossible to get the servo apart to clean without breaking the plastic arm as far as I can tell.
Thank you.
Thank you.
dmh55 (09-18-17)
2003-2006 replacement blend door actuators at Rockauto.
FOUR SEASONS 73310 Heater Blend Door Actuator $ 26.89
FOUR SEASONS 73211 Heater Blend Door Actuator $ 44.79
or
or
Dorman 604-954 Driver Side Main HVAC Blend Door Actuator
Dorman 604-902 Air Door Actuator
