climate control backlight won't turn on
2006 lexus es330 climate control backlight wont turn on, I recently change the headunit, however even when i put back factory headunit backlight on headunit and climate control won't turn on, as well as the light in the ash tray wont turn on, the cigarette power still work, I check all the fuse replace any that burn. still can't seem to figure out why it won't turn on. when i turn off the headlight the LCD on the climate control will turn on. any suggestion
Anyone have an idea what wrong I even try to replace the climate panel still not working feel like it opposite when the headlight on LCD backlight turn off when headlight off LCD backlight on
To be clear you blew some fuses but replaced them? Did you check if they blew again? Are you sure the dimmer is not turned down all the way?
I blew the panel fuse replaced it, I check all the other fuses, I play with the dimmer switch as well all the light on the dash light up, just not the climate control
I don't have a wiring diagram for your model so can't check the fuses/power sources maybe someone here has a diagram. Did you check the fuses with a test light or just visually? Did you cut any wires when installing the stereo? How did you blow the fuse.
I check all the fuse by visual, I used the harness kit from axxess so I didn't have to cut any wire even when I put back the factory headunit it still wouldn't work
I'm having the same problem
I am having this exact same problem with my 2006 ES330. I dont have the cig lighter illumination or the backlight for the climate control LCD. When I turn my headlight switch to "off", the backlight lights on the climate control light up all the way so I'm assuming the bulbs are good. When I put my headlight switch back on "auto" or "on" the dimmer control works for my other lights fine. My shifter indicator bulb is also out if anyone has a good part number for that. I tapped into the cigarette power to run a backup camera when I noticed my cig and power point fuses were blown. I have since taken the 12V ta off for the backup camera and just got power from my reverse lights. I replaced both fuses for cig and powerpoint and they work fine now. Thanks for any ideas.
