2001 Lexus ES 300 Transmission Oil
It used Toyota Type T-IV. Buy it from Toyota or Lexus. Don't use anything else.
It it should be marked on your transmission dipstick. Whatever you do, don't do a transmission flush. Just a simple drain and fill.
I use Valvoline MaxLife, has worked well. About $20/gal at Wallyworld.
A little off (not for the U140E in your car), but I did try OG (ACDelco) Dexron VI in a few older A-series trans (A140E, A541E, A247E). Worked great, but I switched to the MaxLife because it meets the same specs and has seal conditioners for our aging trans. Also cheaper
genji
CT 200h Model (2011-2017)
10-02-23 12:43 PM
dharmaj
07-17-17 05:20 PM
Aman
12-31-16 02:04 AM
