2005 ES330 Service
Old Jun 19, 2017 | 11:22 AM
slantnose's Avatar
slantnose
Default 2005 ES330 Service
My 2005 ES330 was last serviced at a Lexus dealer at 30,000 miles. It now has 69,000 and has just had routine oil and air filter changes along with brake pads. It averages 29 MPG on the highway and has no issues. What is the first thing I should have done to it now as far as service? All help appreciated. Car has been in Florida it's whole life and driven easy.
Old Jun 20, 2017 | 05:32 PM
Oro's Avatar
Oro
I would:
Drain the tansmission pan and refill with fresh fluid.
Flush brake fluid
Replace PS fluid (use a quart of the same ATF as you put in the transmission)
Drain Radiator and refill
That would get you to 100k, when you repeat it all along with changing the timing belt, tensioner, and water pump.
Old Jun 20, 2017 | 05:46 PM
slantnose's Avatar
slantnose
Thank you for the reply. Any idea what kind of cost I'm looking at doing the things you suggested? It will be done at a very good garage with a former Lexus mechanic.
liweil
HS 250h Model (2010-2012)
Mar 27, 2019 09:37 AM
Tyler1986
GX - 1st Gen (2003-2009)
Jan 7, 2017 01:13 PM
Iluvlexus
Hybrid Technology
12
Jan 14, 2013 07:46 PM
skassamali
Aug 20, 2011 04:05 AM
JohnsRX
RX - 1st Gen (1999-2003)
Jun 24, 2004 08:05 AM
