Car Developed a transmission whine
Hey everyone,
I have a 1999 ES300 with 124,000 miles bought the vehicle used and just the other day the car started making like a whine noise when in 1st gear. As soon as the transmission shifts into 2nd the sound goes away. Tranny fluid is full and is still a red color doesnt smell funky. I first thought it was a powersteering issue but the sound only happens when car is in drive. In neutral there is no sound and sound doesn't change when steering wheel is moved. The transmission fluid and filter was changed at 119,000 miles. When I get home from work I will try and get a video to capture the sound. Any info or what to check or advice anything will be greatly helpful.
Thanks.
Thanks.
Something to consider given the history is the filter. I haven't opened that transmission, so I ask other members:
Is the '99 equipped with a wire mesh filter screen like in the U151E and most other Toyota transmissions from this period, or is it a paper cartridge?
OP - are you checking the fluid level:
a) when hot
b) when running, and
c) after shifting through all gears?
Otherwise you will not get an accurate reading.
a) when hot
aroo1986 (06-16-17)
The 99 has a paper filter.
Yes make sure to drive the car till it's warmed up. Park it with the engine running. Set e brake. Shift into drive, reverse, 1st, 2nd, then neutral, then check the fluid.
Don't want to worry you but my 99 had a similar symptom. Started with a transmission whine only in the 1st, took a couple months but it eventually started slipping. Upon removing the transmission it seemed only the torque converter failed but I did a full rebuild anyways.
aroo1986 (06-16-17)
Dysfunctional Veteran
Drivetrain whine is a characteristic of these cars. It is likely the main input shaft bearing. No cause for concern. I have seen cars with many hundreds of thousands of miles on their original bearings and they whine too. While not "normal", it is normal for the age. My 2002 does the same thing in first gear and at parking lot speeds. Still smooth as silk on the highway and runs like a champ otherwise with 160k
aroo1986 (06-16-17)
Thanks to everyone who has responded later on tonight or tomorrow I will try and get a video clip of the sound. For what I paid for the car I'm not really worried engine runs great and the tranny although whines shifts smooth as hell. There is no slipping or anything right now. I only paid 2000 for the ES I had already planned on this being a project car. By the way how hard is it to take the transmission out of these vehicles?
To throw a wrench into this discussion, a whine in the U140E could also be a fluid pump that's worn. That seems to happen too often on these (guess what I've got sitting around waiting for a new pump). If your fluid is in good shape that's a good sign, but I was reading somebody's account on TN that developed problems soon after and the pan magnets were hairy with metal shavings.
aroo1986 (06-16-17)
Do a line pressure test with a fluid pressure gauge attached to the at test port. Monitor idle and stall speed line pressure values for each gear. This will ID a pump anomaly or narrow down things.
But first verify the fill level with the correct procedure and rule out the simple/most obvious things.
aroo1986 (06-16-17)
I have read on here that different years used different transmissions and to count the number of bolts on the transmission pan to see what one I have is this the only way of knowing for sure what transmission I have on the ES?
18 bolts on the transmission pan is the U140
aroo1986 (06-16-17)
That noise isn't the fluid pump. Fluid pump whine will be present in all gears, at idle, etc. Sometimes it modulates a bit in pitch if you have a crescent/variable-displacement pump.
Also, I did a large write-up on several common jobs/fixes to a '99 ES300 a while back on TN. It's still a work in progress, but here's a link to where I installed an auxiliary cooler and inline filter:
http://www.toyotanation.com/forum/10...l#post12279962
...that'll help quite a bit in extending the life of these glass transmissions. HTH
Sorry I have been offline for a while guys but I still can not seem to figure out where to even start to look to fix this problem. So here is a little more info for all you out there.
Car shift fine and smooth
Car goes into overdrive fine
Car doesn't make the sound when in neutral and revved up
I have noticed that when in second gear the whine is there but at a level that its really really hard to hear
so my question is from what anyone has experienced or from what issues I am having does this seem to be narrowed down to it being something funky with the transmission. Should I be looking else where as to what this sound is?
Just saying if you suddenly start getting slippage one morning, we'll have some common ground to go off
EDIT: One more thing. I've noticed sometimes reman torque converters make whining noises. I've installed eBay reman TC's, but nowadays I use the blue Dacco's. The Dacco's have never made noise. across two U140E's, one A140E, and an A540E.
