Headlight help
Headlight help
Greetings fellow Lexuns:
New poster here. I need to replace the side marker bulb in the passenger front headlight assembly on my '05 ES 330. It's just positioned (and too tight) where I cannot unscrew the socket to access the bad bulb. I guess I need to remove the light assembly to get to it. I located and removed the top three bolts, but I am guessing that there is a fourth one perhaps underneath the assembly. I have not yet removed the inner fender well to have a peek under there. Can anyone that may have done this job a or r/r the headlamps - shine any light (ha ha) on whether there indeed is an additional bolt or two on the bottom of the assembly? And if so, does this require pulling the bumper cover away?
Thanks in advance for the help!
mfaile
01-26-07 07:42 PM
