Monitoring Sensor Outputs in Moving Vehicle
How can I read, in real time, in a moving vehicle, the outputs of sensors having to do with ABS and other road wheel movements?
https://www.clublexus.com/forums/es-1st-to-4th-gen-1990-2006/855406-monitoring-sensor-outputs-in-moving-vehicle.html
also if you have to ask you probably shouldn't be attempting whatever it is you are trying to do.
WILLYumD (05-05-17)
Techstream does not show live data from the ABS sensors. It will only show diagnostic codes and allow diagnostic tests to be performed on the vehicle.
If you want real raw data from the ABS sensors, you'd have to rig an oscilloscope to the sensors directly, and spin the wheels to get a reading.
fdibugnara
05-04-17 08:10 PM
