ac control night lights
Old 08-14-16, 01:46 PM
robertog11
robertog11's Avatar
Default ac control night lights
FYI. I finally was able to reach the tiny ac control lights on es300. first i used a plastic small lever kit I got from crutchfield to remove the small dash cover above the cigarret ashtray. I could see the radio bolts on the bottom. I next pried off the air condition grill on top using the same lever . I could see the upper bolts on the radio. I remo ved the four bolts taking care not to drop them and the entire radio/ac dash came off. next i removed screws holding the bottom ac control section on both sides. i then pried out the control unit by removing four tiny screws on both sides first. finally I could see the green board behind the unit. all the little light bulbs are on this board and they twist off to be replaced. now the problem is to find them and buy them. autozone does not carry them. they carry slightly bigger bulbs that probably fit the gear shift area. this for future attempt. I hope this is useful for someone. seems like the hardest part of this job is figuring out how to remove the dash. thank you.
Old 08-16-16, 04:05 PM
speedkar9
speedkar9's Avatar
I made mine using 5050 SMD LED's.
Old 08-16-16, 05:43 PM
Hayk
Hayk's Avatar
These bulbs are sold by Lexus, there is a part number on here somewhere. I believe I included them in my Radio Bulb guide.
Old 08-22-16, 12:22 PM
robertog11
robertog11's Avatar
Default ac ligts.
Thanks mrBooby. I called lexus and it's a special order according to them for $5.30 each. thanks alot again for your help.
2slixx
12-02-16 02:09 PM
daveochoa
SC- 1st Gen (1992-2000)
01-03-06 10:57 AM
Shnerez420
08-11-04 09:10 AM
xx7xx
02-03-04 08:50 PM
jcboiz
09-02-02 12:52 PM
Quick Reply: ac control night lights
