ES330 reverse wire
Old Dec 7, 2015 | 09:14 PM
Dukenukemx's Avatar
Dukenukemx
Default ES330 reverse wire
I'm about to install a new 2din stereo in my 2004 ES330 and going to be installing a reverse camera as well. I have most of everything figured out before a rip apart the stereo except where the reverse positive wire is. I have the TYT0-01 adapter but not sure if it has a reverse power wire on it or not. Doesn't say so in the manual.
Old Dec 7, 2015 | 09:44 PM
There is a reverse signal right at the engine computer, try searching for that info. You can also find it at the back of the instrument panel I don't have a wiring diagram for your car hopefully someone here does.
Old Dec 9, 2015 | 06:06 PM
Dukenukemx's Avatar
Dukenukemx
Thanks, I'm still waiting for the stereo to arrive. Is the engine computer in the stereo area? Also do I need a antenna adapter for the stereo?
Old Dec 9, 2015 | 06:46 PM
Dukenukemx's Avatar
Dukenukemx
Probably just going to run the wire anyway from the truck since I have to for the video cable anyway. Can anyone explain to me how to remove the door step trim so I don't end up breaking it? That's where I plan to run the wires through.
Old Dec 25, 2015 | 01:23 PM
Dukenukemx's Avatar
Dukenukemx
Installation is done and turns out those plastic foot step things just pull out. Wasn't hard at all.
orion603
May 28, 2018 03:16 PM
jaywish
Sep 26, 2013 07:04 AM
SLVRGS3
Oct 12, 2010 06:14 AM
olddog
15
Oct 27, 2006 07:40 AM
mjr24
Sep 19, 2002 12:02 AM
