Why doesnt my car charge my phone?
Old 11-08-15, 06:19 PM
funcrusher
funcrusher's Avatar
Default Why doesnt my car charge my phone?
My side mirrors work, clock works, cigarette lighter works but car charger wont juice my phone when i plug it in. CHarger works fine in my work truck. What can it be?
Old 11-08-15, 07:11 PM
JetsonES
JetsonES's Avatar
Maybe the probe isn't long enough to reach the positive contact?
Old 11-09-15, 12:07 AM
RTF
RTF's Avatar
Idk what year yours is but the plug thingy in mine (2003) ((at least the one in the center console)) is only powered when the car is on. I assume you've tried it with your car on but anyways just trying to help
Old 11-09-15, 10:23 AM
Zacharias
Zacharias's Avatar
I have the same issue with my 1996 and was scratching my head over it.
I just assumed the charger must have popped a fuse. But later when my battery drained I plugged in a charging system diagnostic meter and the lighter receptacle has power.
Odd thing is, the phone charger cord worked for about 20 minutes when I first plugged it in. Then the LED went out.
I wonder if the issue is that the phone chargers are cheap Chinese junk and it's the charger that has failed on me (us)?
Old 11-26-15, 05:54 PM
funcrusher
funcrusher's Avatar
Well my charger is the official one from the phone store. and yep tried it when the car is on.
Old 11-26-15, 06:27 PM
crwys
crwys's Avatar
Check your fuse just to be sure. It's behind the change holder.
The engine doesn't need to be running just need the key in the ON position.
Have you tried the cig in the arm rest/center console?
Old 11-26-15, 06:30 PM
funcrusher
funcrusher's Avatar
I have tried both chargers (ashtray and in middle console). They pretty much charge when they want to. On and off...
I should change the fuse just to do it. Can't be to expensive anyways.
Old 11-26-15, 08:27 PM
crwys
crwys's Avatar
So it sometimes works?
My license plate lights do this sometimes due to crimped wires.
You can swap one of the fuses with something else. Just make sure its the same amps
Old 11-29-15, 11:16 AM
dgbear
dgbear's Avatar
Pop off the center console cover and check the connector that powers the 12v socket.
If you have power at the socket then you have a open from the connector to the lighter socket or your simply not making a good connection in the lighter..
Old 11-29-15, 11:20 AM
dgbear
dgbear's Avatar
After further review... are you sure you don't have a problem with the phone or the car charger?
Have you tied the car charger/phone combination in another car?
Old 11-29-15, 02:51 PM
crwys
crwys's Avatar
OP Said in first post it works fine in his truck
Mitty
05-25-14 04:21 AM
nehal51086
05-31-07 08:33 PM
dfw350
07-12-06 09:46 PM
tgara
05-14-06 08:51 PM
chuckmabie
08-18-03 06:44 PM
Quick Reply: Why doesnt my car charge my phone?
