Stalling at Idle 2002 ES300, Trying to help a friend
Old 07-24-12, 08:46 PM
GS4_Fiend
GS4_Fiend's Avatar
Originally Posted by MrBooby
Is there really no IACV on the 2002? The problem you're having is exactly what a dirty IACV would do.
When the car has Electronic Throttle Control (drive by wire), the car will not have IACV.
Old 07-24-12, 08:47 PM
GS4_Fiend
GS4_Fiend's Avatar
Originally Posted by norcalvp
I completely removed and cleaned the throttle body and the aluminum piece behind it that has the two butterfly valves in it. Both of these components were pretty clean before we started, but now both are squeaky clean.
Smoke test? I have never done a smoke test before. How would I go about doing that? Does this car have an EGR Valve? If so does anyone know where it is?
Your car doesnt have EGR, since you got a VVT engine.
Old 07-25-12, 12:21 AM
Hayk
Hayk's Avatar
How many miles are on this car and does it have any codes?
Old 07-25-12, 12:42 PM
norcalvp
norcalvp's Avatar
140K on the clock, I havent read the codes yet. I was about to check them when I found the threads talking about EGR and IACV so I got sidetracked. I know he has had an emissions code on and off for a while. I will read the codes and get back to you.
Old 07-25-12, 01:29 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Do you smell an exhaust leak?
If the CEL goes on and off, it might be an O2 sensor about to die out.
Check for codes.
Old 10-13-12, 05:42 PM
Excalibur
9th Gear
Excalibur's Avatar
Had the same problem with our 2002 ES300 just yesterday. 141,500 Miles. Had disconnected Neg bat term to reset a code and it wouldn't idle after. Tried the recommendation of running it hard with AC on. No Diff. Disconnected bat again, took inlet air plumbing apart and cleaned the throttle plate and barrel. Blew out air cleaner. Put it all back together, reconnected bat works fine right now. Idle at about 650. Battery was disconnect for at least an hour. Curious to know what the humming is when you reconnect the battery.
danfall4
02-24-16 07:37 AM
nation300
11-09-12 09:42 AM
ilovefood
07-20-09 03:18 PM
buci
03-01-09 06:37 PM
frank_e711
05-18-06 09:37 AM
Quick Reply: Stalling at Idle 2002 ES300, Trying to help a friend
