Low idle fix/setting idle computer reprogramming?
Old Jul 20, 2012 | 04:35 PM
adreano17's Avatar
adreano17
Default Low idle fix/setting idle computer reprogramming?
I idle at 500. I want it to be about in the 700s. I feel it is too low for my alternator to reach turn on speed. Other cleaning the IACV, what else can I do to get it to where it should be. Ideally I want it to be 800 - but I somehow need to program the computer on the car to set idle speed to this. Is the action of reving car to 1000 for 10 min any good to reset the idle speed, or is that for a newer ES? any ideas? thanks.
Old Jul 21, 2012 | 09:05 PM
aujarhead's Avatar
aujarhead
You basically have 2 options. Clean the tb and intake with tb cleaner and sea foam through the brake booster vacuum line or pcv valve vacuum line. You can also adjust the idle speed by adjusting the screw on the throttle cable on the tb. I recommend doing it in the order stated.
Old Jul 21, 2012 | 10:02 PM
adreano17's Avatar
adreano17
The TB was just cleaned. I reset the ECU (somewhat better performance) I will soon clean the MAF. Seafoam is also an option. And I though adjusting the screw on the throttle cable could be detrimental - being that the idle speed is controlled by the computer and not just the cable.
Old Jul 22, 2012 | 07:06 AM
aujarhead's Avatar
aujarhead
If you have a Chiltons manual, it talks about adjusting the throttle and adjustment screw in the fuel and exhaust system section under the throttle body. If I understand it right, if these adjustments arnt right it can cause the idle speed to be off.
Old Jul 22, 2012 | 04:10 PM
adreano17's Avatar
adreano17
I don't have one - and I don't want to pay the money lol. Can you copy and paste the txt?
Old Jul 24, 2012 | 08:54 AM
adreano17's Avatar
adreano17
bump, any other input?
SC3coupe
Dec 6, 2024 01:44 PM
bazzle01
Jan 29, 2018 11:52 PM
sancarlos1
Apr 4, 2017 03:13 PM
clean
Jul 17, 2007 07:23 PM
Eric00GS3
Performance
Aug 17, 2006 08:18 AM
