ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   99' Stuttering problem when accelerating!?!?! (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/583674-99-stuttering-problem-when-accelerating.html)
LuvYurMthr Jul 27, 2011 06:18 AM
I've had my es300 for almost a year now bought used and it's always had a "stuttering" problem when accelerating. It's mostly when the engine is cold BUT sometimes does it when it's been running for a while. I've never mashed it to the floor until the other day out of curiosity. It just cut out until i took my foot off the gas. I've done research and am thinking it's the MAF. Any suggestions would be awesome. THanks
BDSL Jul 27, 2011 08:59 AM
Is there a CEL (check engine light)?
A few years ago, I have a similar issue with my car. At first, there was no CEL. A few days later, the CEL would come on pointing to the EGR valve position sensor. I replaced it and it was perfect after.
LuvYurMthr Jul 28, 2011 05:30 PM
See it's not on and that confuses me. Any other suggestions? Diagnostic test?
rocky321 Jul 29, 2011 08:56 AM
that is MAF meter need to replace, my car got the same problem and one day it was lost all power and died. After replace MAF meter, the car driving normal now. the part will cost you around 150 to 200 depend on the brand. good luck
LuvYurMthr Jul 30, 2011 05:29 PM
Thanks I was debating on trying that. Guess i'll have to give it a go.
Hayk Jul 30, 2011 07:20 PM
Could be that the previous owner messed up the timing of the engine by not aligning the timing belt correctly.
LuvYurMthr Aug 1, 2011 12:15 PM
I'll probably check this out before anything. Thanks.
LEXUS3JR Aug 1, 2011 12:47 PM
please see my new thread here in about 5 minutes. I will explain how I fixed my personal issue. Hope it helps!!!
