Cold trans Shifting issues?
So here is the issue.
When the car is cold it takes about half mile for the car to shift out of first. Once it does this all is fine until i let the car sit for several hour (8hrs).
There are no other issues with shifting, no slipping, no banging into gears. Is this normal to get the fluid up to temp? When i checked fluid seemed a little high. When i checked it i took car on highway for a few minutes followed by some stop and go then parked car and checked.
95 ES300 w/133k on the clock
So I have not had this problem with my 97 es300, but on the mustang that I used to have, it took higher rpms to shift into first when it was cold as you described up above. This was a brand new rebuilt transmission, so I asked Aamco what it was for they rebuilt and installed it. They said that when the car is cold, the torque converter doesn't engage properly. The car needs to run a little bit in order for it to do this. I know they have very different transmissions, but the problem seems very similar. It was nothing to be concerned about though. I just started my car a minute before I left.
i have a 96, and when the engine is cold, it shifts out of first gear right after 3000rpm. i just sorta push it to get past 3000, then its normal driving, and i back off the throttle. not really a problem for me
Matt1
14
Aug 19, 2017 12:21 PM
Thestroomi
Apr 12, 2016 12:52 PM
rickyp39
Nov 5, 2010 12:18 PM
nicos1
Dec 15, 2006 07:03 AM
