Oil problem
Old Jul 12, 2002 | 05:41 AM
LEXBERG's Avatar
LEXBERG
Default Oil problem
Hey my oil lights keep coming on and I just got the oil changed, I looked under the care and I can see some oil wetness,not much. Does anyone know how much it'll cost to get fixed?? It may be some gasket or something???
Old Jul 12, 2002 | 10:23 AM
meZoom!'s Avatar
meZoom!
Super Moderator
you looked under the where???? oil wetness after an oil change is normal IF the mechanic spilled some when removing the old filter or something. if it doesn't go away or gets bigger, or your oil level is dropping significantly, you might have a blown gasket, a crack somewhere, or maybe drain plug not tightened all the way even. i just replaced my valve cover gaskets i forget how much it was but it was a few hundred bucks and that alone takes a whole day.
Old Jul 12, 2002 | 12:39 PM
LEXBERG's Avatar
LEXBERG
WHAT!!!!!!!!!!!!!!!! are you kidding oh lord!!!!! I hope it not that serious. My low oil level comes on every now and then?? there isn't a significant amount of oil I checked the oil level and it was fine. What do you think I'm taking it in on Monday to see.
Old Jul 13, 2002 | 02:43 AM
meZoom!'s Avatar
meZoom!
Super Moderator
well, oil isnt supposed to leak so...it can be dangerous if it does. the mech can't just band aid it up and set you free. yours is a 97...relatively new if u ask me. i dunno how many miles have have or how the car has been maintained but an oil leak is an oil leak. hey are you sure its the engine oil lampthat keeps coming on?? did u check your manual and see what the light means?? it's never happened on my lexus but on another car i had the oil lamp for the BRAKE OIL kept coming on because the brake cylinder couldn't keep proper pressure. or maybe the mechanic hasn't put enough oil during the last oil change?? up to 5 qts will fit.
lysis250
May 31, 2014 06:12 PM
amerquresh
May 11, 2012 06:39 PM
rsr2216
RX - 1st Gen (1999-2003)
17
Mar 20, 2012 08:38 PM
Trebbor
Mar 31, 2010 10:53 PM
jeff1941
Maintenance
May 15, 2008 07:03 PM
