Post 97' ES300 problem/issues
Old May 17, 2009 | 09:29 PM
ssmoked's Avatar
ssmoked
Default Post 97' ES300 problem/issues
I am searching for an ES300 between 97-00 for my friend. Is there any issues that I need to know about such as oil leaks, 02 sensor failure, power steering failure?
I owned a 96 ES300 in the past and the above issues came up with only 96000 miles.
Thanks in advance
Old May 19, 2009 | 02:42 PM
Maxx941's Avatar
Maxx941
I've had my 97 for almost 3 years now, and my only real problem I have come across is my clearcoat on the roof has begun to peel off
Other than that, No problems to report here.
Normal upkeep and changed out 2 o2 sensors.
Old May 20, 2009 | 07:21 AM
ssmoked's Avatar
ssmoked
Bump.
Sorry for the confusion, what i meant was if you know any common issues with ES300 after year 1997.
thanks
Old May 20, 2009 | 08:11 AM
llcoolpass's Avatar
llcoolpass
oil sludge / gel ---> engine failure
big ugly rims, usually chrome, being added to the car
Old May 20, 2009 | 04:47 PM
buci's Avatar
buci
About that oil sludge / gel ---> engine failure = there is no way for you to know before you buy the car.It all comes to luck{as any used car**.You have a 50% chance it will never start every time you put the key in it.I guess this is valid for the 5 speed llcoolpass has also,mine is for sure.
Old May 21, 2009 | 08:04 AM
285exp's Avatar
285exp
I have a 97 with @134k, and an 00 with @66k. I have had the O2 sensors on the 97 replaced a couple of times, also 2 starters. Motor mounts replaced this week, and was advised that the power steering pump was starting to weep a bit. Radio display lcd blacked out. Replaced the O2 sensors on the 00, that's been pretty much it other than normal maintenance items.
gngai
25
Jan 27, 2016 02:53 PM
ChunkyMike
May 26, 2014 05:17 PM
SC3coupe
Jul 24, 2013 06:33 PM
Sendo
Jun 4, 2013 07:14 PM
DJPsystems
Mar 28, 2013 07:00 PM
