es330 electrical problem
My 2005 Lexus es330 has two (related?) electrical problems.
1. The trunk opener inside the car does not operate. The key opens the trunk. The switch is OK (checked with an ohm meter). I checked ALL the fuses under dash and under hood.
2. The automatic seat settings do not operate. The power seats operate properly.
I suspect that a relay under the hood may be the culprit, but the markings on fuses and relays are criptic. Any and all ideas re: the problem would be appreciated. Martin Behannesey
Cane, my friends call me Marty.
The lock out switch did the trick for the trunk release.
I did not program th seats properly after removing fuses and checking them, the memory setting was lost.
BOTH problems are solved.
Thanks a bunch.
Thanks a bunch.
lmaoo i had the same exact problems the program for the memory seats is to put the car in park then set your seats press the number first then the set button......btw the memory seats function dont work when u drivin
kbtr6
Feb 7, 2009 02:54 PM
hi J!
