Headlight Cleaning Problem
Old Jan 9, 2009 | 03:20 PM
tuan92129's Avatar
tuan92129
Originally Posted by Walnut
Thanks, Eyezack.
Now I am wondering...If it's just dust then maybe I could use the vent holes to fill the housing with detergent/water and the agitate the sht out of it. I could probably even drill another vent hole if this would help. What do you think?
I do not recommend doing that. You would wind up with rust, worst lens condition b/c of residue, it won't even dry out after that, and
Old Jan 9, 2009 | 03:30 PM
Walnut's Avatar
Walnut
Hmmmm....point taken...how about this?...I can use a non-residue detergent and do a triple rinse and then put in the oven to dry.
Sounds like a lot less hassle than all that baking and prying and re-sealing!!
Old Jan 9, 2009 | 04:18 PM
eyezack87's Avatar
eyezack87
Better safe than sorry Walnut We don't want you to come back a couple months down the line asking to buy 92-96 headlights
Also, what if the dust/crap is on there tougher than you expected? I had to lightly rub quite a bit with my MF towel to get it off the projector lenses
Its easier than it sounds man. Just takes a day to do it all if you are being extra careful. The second time I did it, it took under 3 hours both sides for everything
Old Jan 10, 2009 | 06:34 AM
Lexucan's Avatar
Lexucan
Lexucanafer
Well, I say Walnut's idea might be worth a try. And after washing it and rinsing it REALLY well and putting it in a warm oven to dry, you might even want to try hooking up a portable blow-dryer for an hour or more (on low setting) to one of the vents (by making up a DIY hose attachment) to dry it out REALLY well inside.
If it still doesn't look clean inside, you're no further behind than if you didn't try washing it, and you can go ahead then with the "heat-and-pry" cleaning method.
Just seems like a lot less "invasive" approach, if it works. Sort of like laparoscopic surgery vs. ripping your chest cavity open.
Old Jan 10, 2009 | 09:31 AM
Walnut's Avatar
Walnut
Exactly!!
Could be trouble though as I had a look yesterday and don't see any definite openings where a liquid could flow nicely into the main cavity in front of the projector lenses
Old Jan 10, 2009 | 06:08 PM
tuan92129's Avatar
tuan92129
Exactly!!
You'll still end up with rust and residue... i remember theres a pic of an es300 after a hurricane, it got flooded and the headlights were 1/2 full of water
Old Jan 10, 2009 | 10:03 PM
eyezack87's Avatar
eyezack87
Well, from my memory, the only openings I could find were the turn signal bulbs are and the low/high bulb holes themselves...
Old Jan 10, 2009 | 10:31 PM
tuan92129's Avatar
tuan92129
There are 3 vent holes in the back.
Old Jan 11, 2009 | 12:52 AM
eyezack87's Avatar
eyezack87
Thanks for the clarification lol
johnyboiiy
Sep 30, 2008 08:37 AM
AkiD
GS - 1st Gen (1993-1997)
14
Nov 8, 2006 02:50 PM
wantalexus
Automotive Care & Detailing
Dec 4, 2003 07:41 PM
Hopeful
Aug 27, 2003 04:59 AM
