bad mpg almost nothing wrong with the car
my 94 es300 is getting 17mpg on 70% highway on 30% local driving without AC. i did some search on the forum but didn't find any answer because i ran the ECU code there is nothing wrong. some times P0402 Excessive EGR flow comes on once a while it will come off itself in 1 day. my question is even the ECU didn't indicate the o2 sensors or pcv valves have problem should i change them anyway? any other stuff will cause low mpg?
i changed the spark plugs and PCV valve. mpg seems getting better. but the cel came on tomorrow says the o2 on the bank 1 needs be replaced, i know o2 sensors are something will decrease your mpg. do you know where i can get some cheap o2 sensors? Bosch or Denso brands
the bosch work fine, the universal part
you just crimp or solder to plug of OE part... keep same length and nothing will be different.
I get 20 to 21 mpg 50/50 [and that 50 is high speed, so its actually quite good mpg]
avalon42
19
01-31-10 09:50 PM
