need help!!smoke under the hood
i have a 96 es300 and smoke is coming out of the hood. when the car is on for about 7 or 8 mins little smokes start coming out from under the hood. does anyone knows whats wrong?? please help me. tahnks..
How many miles on?? I had the same exact problem about a month after I got my 95'... It was the valve cover gaskets.. Check the front valve cover for noticible oil on the block, then the rear one.. my turned out to be the rear...
It was a pain to change the first time around for me... But it allowed me to change all the spark plugs.. GL
Yea, that is oil leaking onto the exhaust manifold(s). Check your oil cap first as they tend to be getting older with our vehicle's age. Can you take a picture of your valve cover and post it? We can probably point out the leaks to you. Once you get it fixed, use engine cleaner on all the exhaust components in your engine bay to get the set in oil off.
If it's not the valve cover gaskets, it could be the head gasket. I replaced my valve cover gaskets, tube seals, oil cap, checked the distributor and it still leaks oil and smokes up. So I'm guessing it could also be the head gasket if not the valve covers.
Im assuming having the shop do it will be pretty costly labor wise, expect 2-4 hours... Gasket itself was $20-30.
I'm not so mechanically savvy myself, def. needed another to help. GL
You will need to buy the gasket set (I like FEL-PRO), which includes 2 valve cover gaskets and 6 spark plug slot gaskets and a bottle of blue rtv sealant. Plus, you get to do an oil change during the process! You might as well change all the gaskets touching the intake manifold while you have it off as routine maintenance.
Wrestling with the wire harness while youre trying to get the rear valve cover in/out is my personal favorite part. My shop pays 2.8 hours for a 1mz and I think 2.3 on a 3vz. 3vz's are much easier to do.
I dont think that is possible. The engine sits at such a huge rearward angle, so its almost guaranteed that the rear will leak first. Regardless, you should do both valve covers because if its not leaking now it will soon.
acosta96
07-24-18 04:52 PM
dbui
RX - 1st Gen (1999-2003)
06-03-15 05:37 AM
