Need Help Seafoam'ing...
Old 11-03-07, 10:35 PM
shahir18
shahir18's Avatar
Default Need Help Seafoam'ing...
i have searched soo many times and looked at all the instructions and DIY's but in my '01 es300, i cant find the brake booster hose nor the correct vacuum line
can someone please help me with pictures/instructions... also how can i clean the iacv/tb without opening everything up?
-thanks!
Old 11-04-07, 02:46 PM
MoreMGD32
MoreMGD32's Avatar
im not sure about the brake booster, havent heard about that one...however the vacuum line that you need connects to the intake manifold(theres only one and its usually under the manifold). so disconnect that hose so its still connected to the manifold itself. you may need a pair of pliers to disconnect the clamp.
As for the process of getting it in the manifold:
The engines natural suction should suck the seafoam into the manifold but its alot easier to have a friend to rev. the rpms to like 1500-2000 to prevent the car from stalling. other wise you have to do it slowly(very slowly or keep restarting your car).
You will need a very small, shallow tupperware to pour the seafoam in b/c the can wont fit behind the manifold. (if your rico suave like me, you can use an old spray paint can top so you dont have to do anymore dishes.)
The fun part:
After your done adding 1/3 of the can in the vacuum line, 1/3 into the gas tank, and 1/3 into the oil reservior, let her rip! rev the engine to like 3,000 rpms, 5,000rpms, then hold it at 4,000 and watch all the black/white smoke come outta the exhaust.
If your engine was really in need of the seafoam treatment the smoke will be black, if not white.
Fyi, do it in a well vented area, not in a garage....theres a lot of smoke!!!!
Old 11-04-07, 07:53 PM
shahir18
shahir18's Avatar
can you take a picture and point out which one it is...
Old 11-04-07, 08:31 PM
MoreMGD32
MoreMGD32's Avatar
ill try, might be a few days.... but ill have them asap
Old 11-04-07, 09:36 PM
shahir18
shahir18's Avatar
thanks... just dont want to get the wrong hose!
Old 11-05-07, 12:50 AM
fwynn
fwynn's Avatar
https://www.clublexus.com/forums/sho...t=185227&pp=15
Old 11-05-07, 06:38 AM
shahir18
shahir18's Avatar
i have seen that thread, but the problem is my engine is not the same... i have no hoses on that side of my manifold!
Old 11-05-07, 07:57 AM
bunthy
bunthy's Avatar
check the driver side firewall. there should be a BIG black round drum, opposite of the steering wheel in the engine bay. Thats your brake booster. disconnect the hose theres with a plier and slowly add the seafoam. Shut off engine, wait 5-30mins, then give it a start, may take a few attempts.
Goodluck.
Old 11-05-07, 09:49 AM
Choas
Choas's Avatar
^Very likely will stall out the engine so you might want to have two people. One to pour in the seafoam one to rev the gas to keep it running.
Old 11-05-07, 04:17 PM
TORTOISE
TORTOISE's Avatar
I wana try this too but my dad wont let me.....he says he has heard of people ruining their whole engine.
Old 11-05-07, 05:26 PM
BadViper22
BadViper22's Avatar
IF you guys are unsure how to do it just go to youtube and search How to seafoam. I swear i saw a guy do it on his 4th gen Camry on there.
Old 11-05-07, 06:23 PM
fwynn
fwynn's Avatar
my car.... not es but sc :] http://www.youtube.com/watch?v=2hrasAYG42g
Old 11-05-07, 06:40 PM
BadViper22
BadViper22's Avatar
2jz, eh its not a 3vz or a 1mz but it's close enough for visual purposes.
Old 11-05-07, 08:26 PM
TwiztidLex
TwiztidLex's Avatar
I've Seafoamed my ES, both my 240's, and a friends 300Z. I used the brake booster hose every time with no problems. The brake booster runs from your intake manifold to your brake master cylinder, simply disconnect the hose from the brake master cylinder and with the car running insert the hose into whatever it is you are using to hold the Seafoam and the hose will do all the work. The car will then stall out, don’t worry this is normal, wait 5 minutes and then restart the car. This may take a few attempts but it will restart. Then run the motor until it is done smoking.
Old 11-06-07, 11:41 PM
eyezack87
Camry ConeKiller
eyezack87's Avatar
I believe you meant this video =)
http://www.youtube.com/watch?v=SZf4WXwVL_E
Quick Reply: Need Help Seafoam'ing...
