Wheel Fitment Issues
Ok I finally got my new wheels mounted and balanced and on the car. The fit pretty nice but my rears seem to rub against the strut tower when I got over slight humps in the road. I have 2 15 inch subs in the trunk and it adds about an extra 75lbs so I removed them and I still rub. At first I thought I was rubbing on the fender but after driving today and checking I saw it was the strut tower. I'm not sure how many people are running spacers but do you think they would help correct my problem? The wheel sizes are 19x8.5 +35 offsets tires are 235/35/19 (should have went with 225 or 215s for some stretch but I'll fix that eventually:sad:)
I do know depending on what size spacer I would have to get longer studs. I'm trying to avoid that at all costs. In the next month or so I'm going to be switching to coilovers or if I can convince wifey a custom air setup. :D I'm just trying to fix the rubbing until I switch to coils. But here are some pics to kind of give you an ideal of the fit. http://i28.photobucket.com/albums/c2...1257Medium.jpg http://i28.photobucket.com/albums/c2...1258Medium.jpg http://i28.photobucket.com/albums/c2...1259Medium.jpg http://i28.photobucket.com/albums/c2...1260Medium.jpg -Smitty |
A few more pics
http://i28.photobucket.com/albums/c2...1264Medium.jpg http://i28.photobucket.com/albums/c2...1261Medium.jpg http://i28.photobucket.com/albums/c2...1263Medium.jpg Not flush yet but hopefully soon. Maybe I'll add just a tad bit of negative camber. Not too much she is a Daily :D http://i28.photobucket.com/albums/c2...1265Medium.jpg -Smitty |
Looking good Smitty! It's really VIP now. Which coilovers are you going with? Depends how much you're rubbing. 5mm and up it's recommended to get longer studs. Maybe try 3mm? How do you know it won't rub when you go with coilovers?
BTW is there a 3 piece spoiler for the ES? The one you have right now looks out of place with your theme. |
So i see your in the same boat I was about a month back but it was my rim itself rubbing on the strut tower. I ended up trying 5mm spacers in the rear that didn't do a thing but make it hard to put the rims. So I ended up getting 12mm spacers which forced me to get longer studs. Now if this is the route you need to go you will need; a guy good with a sledge hammer, a guy to hold a board over the spindal so you don't damage the abs, and a brave guy to hold the pointed hammer up against the stud while the guy with the sledge hits it. But they do look go just be happy its not the rim itself rubbing. Let us know about the coilovers and how that could fix it because what I thought it would do it just raise or lower the car not make to strut tower more out of the way so it doesn't rub. Also about my bumper you never got back to me is it a no go? I kinda need to know its going to get up on the lift soon and I need to know what parts i'm taking off?
Originally Posted by ChrisES
(Post 2694501)
That off-set seems to be a little off...mine is +43, and its like a 1/4" from the strut already.
I actually had to buy a pair of 3mm (or maybe 5mm, can't remember) wheel spacers to clear some Dunlop's that had a thick rim lip protector on them. You defiantly should have gone with 225 or 215. I learned my lessen, I threw away a few hundred dollars for 235 The wheels look good BTW GL of the wheel fitment |
(Post 2694501)
Originally Posted by Choas
(Post 2694565)
I was reading your post and I was trying to avoid the longer studs since I read how much trouble it was for you the get yours on. If I have to go that route I'm going to be a punk about it and pay someone to do it. :rolleyes:Yeah I know it goes against my DIY mentality but I just dont feel like going through all that right now. I've been having enough problems working on my bike. :D But in all spacers would probably work? And are they safe to be rolling on? Any vibrations or problems? -Smitty |
it looks like the tire would rub on the inner fender lip
Originally Posted by Smitty0881
(Post 2695321)
Well when I go with coilovers I'm thinking of going with the Ksports and adjusting the camber a little so maybe it wont touch. :sad:But that is a good question. And about the spolier that was on the car when I got it. I'm seriously thinking about removing it and getting a M3 style spoiler or no spoiler at all. :D
Sorry its taken a while for me to get back with ya. I sent a PM. I was reading your post and I was trying to avoid the longer studs since I read how much trouble it was for you the get yours on. If I have to go that route I'm going to be a punk about it and pay someone to do it. :rolleyes:Yeah I know it goes against my DIY mentality but I just dont feel like going through all that right now. I've been having enough problems working on my bike. :D But in all spacers would probably work? And are they safe to be rolling on? Any vibrations or problems? -Smitty No vivration at all they actually are smoother feeling than my snows |
DAM THE REARS ON THE ES!!! :wild: What to do what to do.... I guess I'll try to find some spacers from a local parts store and see what happens. All else fails I'll get longer studs and get the right spacer and fenders are being rolled and pulled Monday so We'll see how it goes. I'll keep everyone posted.
-Smitty :D |
looking good...
i believe a 3mm spacer should do the magic.. |
Update:
Ok I took a very very close look at my rears Saturday and I was rubbing on my fenders. I've been calling around for the last week trying to find a shop to roll my fenders but couldnt get anyone to do them soon. So I went about it old school and used the bat/fender roll trick. Pulled out the blue painter's tape, the heat gun and my bat and got her done. :D No more rub. Still want to push the rear tires out alittle to get the flush look I'm looking for but that will happen in due time. Fender Roller ;) http://i28.photobucket.com/albums/c2...1278Medium.jpg http://i28.photobucket.com/albums/c2...1280Medium.jpg Pictures from Saturday at Sandy point beach http://i179.photobucket.com/albums/w...s/100_1873.jpg http://i179.photobucket.com/albums/w...s/100_1874.jpg http://i179.photobucket.com/albums/w...s/100_1875.jpg http://i179.photobucket.com/albums/w...s/100_1877.jpg She's coming along. Definitely more to come. :D -Smitty |
She's really coming along nicely. I see you went my way with the fender rolling. Did you crack any paint? :sad: When are the coilovers coming in?
(Post 2700700)
(Post 2700599)
Update:
Ok I took a very very close look at my rears Saturday and I was rubbing on my fenders. i tried to tell you! |
