window problem
On my 93 ES 300 both of the left windows dont work also the right rear window doesnt go down from the driver side only if some one is back there pushing the button but i can bring both of the right ones up whats up with that?
Suggest a combination of errors...
If you hear the motor run on the left side windows, their regulators need to be removed from the doors and checked for stripped gears.
All the door switches go through the master (drivers) door switch assy. This is for the lockout feature in the drivers switch assy. Your right rear switch in this assembly may be faulty.
