Fixed Check Engine.TRAC off problem
Old Jan 12, 2007 | 06:20 AM
Lex99's Avatar
Lex99
Originally Posted by lexusk8
Lex99, have you brought your car to an Autozone or Advance Auto Parts store to get the error code(s) scanned? If not, you should do so. It's a free service, and will give you the exact identification of the source behind the check engine light/traction control off problem. Just because the TRAC OFF light is on doesn't necessarily mean the traction control system is not working. When the CEL and TRAC OFF come on, the car is running in "fail-safe" mode, so your car should be OK to drive for a while. The problem is typically emissions-related (i.e. O2 sensors, charcoal canister, etc.)
No, I haven't had a chance to visit a local auto parts store for diagnosis. I will make it a point to do so. I'm motivated to fix the issue to restore my traction control system. I guess general concensus is that it's the primary o2 sensor.
What I'm trying to learn/gather from this thread is; if the replacing the o2 sensors fixed everyones issue? If I go to an auto parts store and they say, "it's your o2 sensor" will it actually be as stated?
Thanks for your time.
Old Jan 12, 2007 | 10:17 AM
lexusk8's Avatar
lexusk8
No, the error code scanner won't actually say what the problem is, but will give you an error code number in the format 'P####' where each # stands for a number 0-9.
Do a search in this forum for "trouble codes" and you'll find plenty of threads discussing about this in the past.
Gpalmos
Jul 10, 2019 03:59 PM
ameer90
Nov 11, 2016 05:28 PM
ganlake
Sep 5, 2009 01:34 PM
2fity
Jun 9, 2006 11:26 PM
koolkat1973
Performance
Feb 25, 2002 02:55 AM
