Power steering line/hose leaking bad!!!
3rd Gear
Wassup family. I have a 05 Es330 nd I got a bad power steering leak my ppl but im by my self nd cant turn the wheel nd check for the leak at the same time. Based on the video, dies anybody kno whuch hose or part number this is that leakin lik this?? Also has anybody had this same issue b4? Thanks in advance and i hope someone has sum info lol
her is a link to see sum videos https://we.tl/t-FOygVNRDxQ
Hello,
That's one of the least legible posts I've seen around here bud..
It would be helpful if you can upload the videos to YouTube, making things a lot simpler, you can make them private in the settings, and it is not hard to do. Either way, the most common leak point in those cars is the Pressure Line from the Power Steering Pump to the Rack, which goes along the firewall behind the engine, it has a crimped portion that tends to fail over time, if the leak is bad, you will see the damage even without having to turn the wheel just by looking at it.
Hope this helps and best of luck!
Fastfwd
Performance & Maintenance
12-14-08 03:53 PM
