12V battery
12V battery
I have a lexus CT 200H hybrid, I just wanna know if in case i am gonna leave town for few days and my car is left behind, can i remove the terminals of my car's 12V battery to prevent any drainage for the period I am away?
A few days should not be an issue. If it is, then your 12 volt battery needs replacing anyway.
Removing the terminals on a modern car will most likely wipe your "settings" which you will have to reprogram? IDK. I wouldn't do it.
Might want to buy a battery tender so you don't have to disconnect it.
you are fine if just a couple days. even a couple months is fine. i wouldn't start worrying until you get into the half a year range. then at that point i'd just connect it to one of those plug things to keep it from discharging
dxerg3770
ES - 6th Gen (2013-2018)
47
09-12-24 10:44 AM
TLPLEXUS
HS 250h Model (2010-2012)
10-13-18 03:44 PM
