OBD port hardware question
So I asked the same question earlier today in the "other" forum, and have gotten no answer. Thought I would try my luck here. Here goes:
As I was cleaning my car yesterday afternoon, I noticed that the On Board Diagnostics (OBD) port has kind of slight wiggle or play on it. In other words, it seems it is not in a fixed location and you can wiggle/shake it around a bit.
In case you don't know, the OBD port is located underneath the steering wheel towards the left side. A picture of its location is here:
http://www.outilsobdfacile.com/base_...ring-wheel.jpg
(Notice the red rectangle). The port is sunken in that location. Once you put your hand there, feel for a port similar to the old printer ports. Once you feel the OBD port, lightly push the port left/right back/forth. Please let me know if your car's OBD port also has a bit of a movement in it or is it completely fixed.
The reason, why I am asking is because, my other 15 year old car's OBD port is fixed and is completely unmovable.
In a way, I have a feeling Toyota/Lexus has made it a slightly movable deliberately so that all different types of OBD scanner can fit in that sunken port location. But I want to make sure you guys also have a small play in your OBD port. I know my dealership's techs access the OBD port to reset the TPMS every six months. Hopefully they haven't damaged it inadvertently.
Thanks in advance.
Thank you. It's a great relief to hear that my car isn't faulty.
Thank you.
James
