CT 200h Model (2011-2017)
Fog light fix
Old May 18, 2024 | 02:40 PM
Neophyte2b's Avatar
Neophyte2b
Default Fog light fix
My fog lights won't turn on even after I changed the bulb. Could it be the fuse? I believe that the fuse for the fog lights is ECU IG1 No 1 or is it FR FOG. Since my power windows work, can I assume that the ECU IG1 fuse is not the reason for the fog lights not turning on? How likely is it the relay, or is a different fuse that controls the front fog lights?
Old May 18, 2024 | 06:17 PM
TobiasSing's Avatar
TobiasSing
1) Make sure the high beam isn't on (make sure the stalk isn't pushed in)
2) Make sure that the low beams are on (illuminated)
With those conditions met, when you turn on/off the fog light switch, are there any relay clicks? Does the green light on the instrument cluster illuminate?
Labrati
GX - 2nd Gen (2010-2023)
Mar 24, 2024 07:41 AM
v1mike
Aug 25, 2021 04:44 AM
Tman6852
Oct 14, 2017 12:06 PM
calichris
Apr 18, 2008 06:13 PM
is250al
Feb 8, 2008 10:46 AM
