Meguiar's Solo Wool Heavy Cutting Pad 7 inch At ProperAutoCare.com
The Meguiar's Solo System Wool Heavy Cutting Pad is specifically designed to work with Meguiar's M86 Cut & Polish Cream and the Meguiar's W66 "Easy Buff" Backing Plate. The Solo System Wool Heavy Cutting Pad is 7 inches in diameter and flat vs what could be described as a "dish pad", like the shape of many wool pads. The flat pad design of the Solo System Wool Heavy Cutting Pad expands the cutting area to reduce buffing time compared to curved wool pads. When used with the W66 backing plate, you can use this pad to buff up to the edge of panels and actually "feel" where the edge of the pad is while keeping the pad flat to the surface. You should never tip the pad or buff passed sensitive areas.
These Meguiar's Solo System Wool Heavy Cutting Pads are 100% wool 1 inch twisted fibers for faster cutting. Most wool pads in the industry are 1.5 inches or longer. The longer length is not needed for defect removal capability but exists to provide the user with a soft cushioned buffing feel and to provide a safety against "burning edges." The 1 inch pile removes defects more effectively while the W66 backing plate provides the cushioning needed for safer buffing.
These pads are effective in removing sanding marks and defects. They are designed to work on a rotary buffer only. Dual action or orbital buffers are not recommended with these pads.
99alta
Automotive Care & Detailing
05-26-15 06:36 PM
