New Product FIGS CNC Billet Battery Bar V2
Bars are back from Anodize.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Mike
__________________
Thanks for the info, Mike... I forgot to follow up on this after installation. I think it looks great. However, I may have used the new J bolt incorrectly.. In the only position I could get it to catch the underside of the battery tray, it ended up being too long up top. After tightening the nut on top, the J bolt was protruding an inch or more above the bar. I ended up just cutting it down with a hacksaw. Anyway, it hasn't moved or loosened up yet (it's been nearly two months), so it seems fine.
-Mike
-Mike
-Mike
-Mike
How do I know all of this seemingly useless information? I put a lightweight battery in my car, figuring out a mounting solution has been an adventure, at one point I accidentally installed the hook as I described above. It was fine for a couple of months, but the sheet metal will bend quite easily so if you do have this happening I would correct it. Use a flashlight and look down at the base of the tray, if you see any of the sheet metal other than the tiny little tab opposite the hook it is installed incorrectly.
