Gathering Interest GI: 15"(380mm) front and 14" (true 360mm) rear BBK
Hi guys, we are done with the pre-design on our new BBK featuring a 380mm front 6POT and 360mm rear 4POT and I wanted to see how many would be interested. 19" min wheel will be required but the calipers are extremely efficient and compact so they should offer a wide range of aftermarket wheel clearance (stock confirmed).
The kit is made by our tried and true brake manufacturer, RacingBrake, who has done extensive testing with the same ring sizes on the Nissan GTR. These are 100% made in the USA in Fullerton CA and the technology is on par with any of the European manufacturers at significant cost parity. A 2-piece center-mount floating rotor design is part of the package as are several pad compounds. Looking for interested people to help us with the product pilot and trying to get 5 packages sold before we pull the trigger on the run.
Here are some pics.
we will also have a hard anodize black option for an additional charge. Pricing is set around $6199 but I am working on the final numbers based on how many I can build up front. PM with any additional questions.
Mike
Here are some pics.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Sorry ERDoc74, I replied but looks like it did not post it. What would you do with the calipers only? These are complete kits, calipers, loaded,lines and 2 P rotors. We will also have a true 14" kit front kit with the same calipers.
I am just going to do it since no chime ins. Production to start next week.
__________________
These will surely look great behind the wheels. I actually like that color of the calipers pictured.
I might just have to upgrade yet again from the current 2 piece rotors to this which should be the last brake upgrade ever needed. Having brakes that cool more efficiently then the bulky stock calipers would be a good improvement.
Preorder cart is up as well as intro pricing good through the end of June. http://shopfigs.com/v1/index.php?rou...product_id=242
__________________
first kit is in and will be installed later this week. Rear rings ar enow EDP coated so that we can cover more applications without a rust area on the unused portion. This will be the offering as soon as the existing rings are depleted. Rear is a true 360 vs the factory front which has a 355mm wipe.
__________________
some instagram pics of the first fitment. Calipers are back from getting coated orange and getting assembled and back to us in a week.
front 380mm 6 pot BBK
rear 360 4pot BBK
rear 360 4pot BBK
__________________
does anyone have these installed with pics, or can otherwise comment on them?
was wondering if anyone knew the net weight savings difference between these and the stock kit (i know the rotors are lighter)
thanks, just curious of peoples experience with em.
__________________
Bump for the best performing (and looking) balanced big brake kit ever built for Lexus offered by Fig. Note RB is the only brake company offers the rear BBK with drum parking brake integrity, unlike competition either they tell you that you don need it or to delete your rear parking brake.
http://www.focusrs.org/forum/15-focu...tml#post974313
Learn how RB rear balanced brake kit corrects Viper's too heavily biased rear brake that those track drivers had to put up with for decades
http://driveviper.com/forums/threads...ht=racingbrake
Mike, It would be helpful if you can post a picture after breaking in (let the disc shine after those protective paint were off) - as is now since installed.
We have in other threads but here is the car as rolling with both front and rear BBK's after bed in. Same pic as in our signature.
__________________
CleanCL
Suspension and Brakes
10-04-10 03:04 PM
illmike
07-07-08 11:16 AM
ddquach
01-08-08 06:27 AM
