Recon.......
#32
im just gonna have to spend some more money and see if i pass. lol. hopefully i pass so i can. hit or miss on the suspension travel now eh? i guess i'll dress nice so i get more of a chance
#33
#34
^^ AFAIK you can't get recon for air suspension... When you align your car to the requirements it needs then your vehicle is straight... No plus/minus degrees or positive/negative camber... But once you play with air then there is no telling that if your car is truly aligned or not because of the drastic change in wheel/suspension alignment... Hence that its impossible to get recon...
#39
No. It just needs to be within factory specs. The numbers are never a single specific number, but a range. It may be something like: Front Camber -0.5 to 0.8 degrees. Rear Camber -0.8 to 1.0 degrees, or something like that. As long as the actual camber falls within that factory spec it is considered aligned.
#40
Master Thread Closer!!
triplecore
09-03-06 06:42 PM
