The perfect engine for today’s small sedans and crossovers?
From his post, actually I oversold it:
And as was said above, lots of turbo 4 cyl are over 300 hp.
This little V6 just has no relevance today.
It was rated at 129 HP at 6000 RPM and 157 ft-lbs of torque at 5000 RPM
Not a lot more power. Theres only so much they would be able to get out of a NA 1.5L V6. The Toyota/Lexus 3.5 only gets 300. The question is today which would you want, a small low powered NA V6 or a modern turbo 4, the turbo 4 is going to feel a lot more powerful. In the Avalon I have right now, the 3.5 is smooth but you have to get the RPM up over 5,000 to get any kind of meaningful power. Hard to go back to NA when you're used to turbo power.
Actually you can get 320HP out of an IS350 with an RR Racing tune, PPE headers and a bigger exhaust. The RR Racing tune brings the Redline up to 7200 RPM. PPE headers are not CARB compliant in California, so I was considering buying the tune, but it wasn't worth $600 just gain 14 hp
Not without forced induction using a Big turbo (or twin turbos), which means now adding an intercooler, oil cooler, additional cooling and there goes reliability
LOL nope, not with a 1.5L. When I was part of the Honda Civic Si forum, people were putting bigger turbos, downpipes, and even Flex fuel kits to get near 300 hp and were blowing their engines and clutches left and right
However, like I mentioned in the write-up, the current state of the auto industry has become so obsessed with electric powerplants that we are not likely to see any serious attempts at doing (or redoing) a small V6.
One does not need 300 HP in the average subcompact sedan or crossover. However, with today’s powertrain engineering, a lot more than the 129/157 power figures for that original 1.8L V6 could easily be done with the same block…even without forced-induction.
Super Moderator
There's a little more nuance to it than this, but the simple math says if you can get 300hp out of a factory 3.5L NA V6, an engine of a similar design but half the displacement should give you somewhere in the neighborhood of 150hp. Let's be generous and say 180hp if you take advantage of the lower piston mass to make it rev out to 9k rpm or something like that, but then again that runs counter to the stated goals of the thread.
